Overview
This VI determines the frequency of a trigger to an NI framegrabber.
Description
This example measures the duration of time between acquired frames using the tick count millisecond timer. After finding the time between frames the value is then converted to Hz.
Caveats and Additional Notes:
1. This VI will need to be aborted if there is no trigger to be read because it will never leave the inner loop.
2. This VI is dependent on software timing, so accuracy is best at slow triggering rates.
Requirements
Software
LabVIEW 8.0 or Later, Vision Acquisition Software
Hardware
NI Framegrabber with external trigger lines, Camera compatible with Framegrabber, Trigger source such as a DAQ device.
VI Snippet
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
