Example Code
IMAQdx Grab and Save Individual Files
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
    Driver
  • NI Vision Acquisition Software
Code and Documents
Overview
The example demonstrates how to acquire images and save them to series of images or a video.
Description
The example shows how to use an IMAQdx Get Image to save each frame as an individual image file (formats: BMP, JPG, PNG) or a video (format: AVI). In case the frames of the camera acquisition are saved in image files the file name is automatically incremented.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • Vision Development Module 2012 (or compatible)
  • NI-IMAQdx 4.0 (or compatible)
 Hardware
  • NI-IMAQdx driver supports the following buses and standards:
    Gigabit Ethernet Cameras Supporting GigE Vision, FireWire IEEE 1394 Cameras, USB 2.0 Cameras Supporting Microsoft DirectShow (often called 'webcam'), USB 3.0 Cameras Supporting USB3 Vision
  1. Open the attached file
  2. Select the file format to save the images to
  3. Select the path where the file(s) are saved to
  4. Select the file name
  5. Select the camera name
  6. Run the VI
Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Daniel Hays | Test Software Business Manager
Comments
easayed
Member
Member
on
Dear All
i just tried this vi it works well
thank you so much
chetouanic
Member
Member
on
hello
i have labview 2011 it didn't work for me 😕 can you tell me how to fix it ? thank you
funan89
Member
Member
on
Hi, I used your example VI "Grab and save to jpg".
Everything works fine, but I only see blue images. This happens with both my cameras, a "ZWO ASI290MM", and a "Tuscen IS300". Both of them work fine with their native image viewer software. However in labview it only gives blue image.
Does anyone face this problem too?
I have edited the sub VI to test it out, and the image returns a blue screen even when I link the IMAQ temp memory storage straight to the indicator. Below is the edited VI. (I get the blue screen even when using the unedited version), also the blue image and the numbers below fluctuates a little using both the edited and unedited VI, which is strange cause the same data goes into the while loop.
Bylka
Member
Member
on
hey i tray to acquire images and save them but with labwindows and i'm bigginer in using LABWINDOWS searching for help how to process thanks
