Overview
This VI uses a camera and Geometric Matching vision algorithms to identify one of the 25 pieces from the board game Perfection.
Description
First, a Geometric Matching template was created for each piece using the NI Template Editor that comes with the Vision Development Module. Within the VI itself, an array of these template images is created. When a piece is placed in the camera's view and the program is run, the camera takes an image and compares the image to the 25 piece templates using the Match Geometric Pattern 2 VI. The template with the best match score is determined to be the correct piece, and that piece is displayed on the front panel along with information about the piece such as rotation, position, and scale (in relation to the template image).
Steps to Implement Code
1. Download Identify Piece.zip
2. Make sure the VI and the Perfection Templates folder are both contained in the same directory
3. Place a Perfection piece under a camera or select a sample image
4. Run the program
Requirements
Software
LabVIEW 2009 or later
Hardware
Vision Acquisition Software compatible camera (optional but recommended)
Perfection (or Perfection Pieces)
Additional Images
Front Panel:
Block Diagram:
