Overview
This example VI shows how to resize image and convert format for images when default interpolation mode is sufficient.
Description
You can resize image and convert format for images when default interpolation mode is sufficient.
Requirements
1.Selection the path in the front panel.
2.Run the VI
Additional Information or References
VI Snippet
it is marvelous to see the image resize vb.net map there. cool job. when can the default interpolation be sufficient.
