Example Code
Image Threshold
Code and Documents
Overview
This example illustrates different image thresholding algorithms, Local, Automatic, and Manual.
Description
Local thresholding calculates local statistics for each pixel in an image. Based on the calculation result, the algorithm categorizes the pixel as part of a particle or the background. Automatic thresholding uses the histogram of an image to compute a single threshold value for the entire image. Manual thresholding uses a specified range of values to compute a threshold value for the image. Refer to the NI Vision Concepts Manual for more information about thresholding algorithms.
Hardware and Software Requirements
LabVIEW 2014 or compatible
Vision Development Module 2014 or compatible
  1. Download both Image Threshold.vi and IMAQ Vision Example folder.vi, or find the example by going to Help >> Find Examples >> Toolkits and Modules >> Vision >> Image Processing, and find Image Threshold.vi
  2. Run the Image Threshold.vi
  3. Click on the different Threshold algorithm tabs to see how each algorithm works. The local threshold is the most robust algorithm when there are lighting variations in the image.
Additional Information or References
Front Panel:
Alyssa H.
Applications Engineering
Contributors
