Example Code
Implementing a Timeout Using the Elapsed Time VI in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to use the Elapsed Time Express VI to implement a timeout case in an overall application.
Description
This VI demonstrates how to use the Elapsed Time Express VI to implement a timeout case in an overall application. You have the option to either manually reset the timeout based on an event firing (in this case asserting the boolean switch on the front panel) or it resets when the timeout value has been reached.
Requirements
LabVIEW Base Development System 2012 or compatible
  1. Enter the Timer Timeout (s) value in seconds
  2. Run the VI
  3. Notice that the Timeouts value increase whenever the time elapsed passes the Timer Timeout
  4. Press the Reset switch to restart the timer and increment the Number of Resets by 1
Additional Information or References
Note that elapsed time is being polled as is not execution timing (makes the While Loop sleep) therefore the Wait (ms) is necessary in the application
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Jonah Paul
Marketing Manager, NI Software
Comments
Todd S.
NI Employee (retired)
on
Thanks for posting! Could you please rename your attachment to include the LabVIEW version ("_lvXX.vi" is fine).  Also, please include a screenshot to give us an idea of what we're downloading.
Todd S.
LabVIEW Community Manager
