Overview
As with most elements in TestStand, you can customize the Execution Viewer to include expressions and additional information about each step.
Description
This example adds a conditional expression to a new colum in the execution state of the execution viewer. This colume is not visable at edit time, but displays measurment information with Numeric Limit Tests and Multiple Numeric Limit Tests. For all other tests it displays a empty string.
To do this modification from the Sequence Editor, right click the steps panel » Step List Configurations » Edit Step List Configurations.
Here you can edit and customize you edit time display as well as exeution display.
I created a new configureation and added a new expression column to it.
The expresstion I added grabs the results from the tests and formats it correctly.
(RunState.Step.StepType.Name == "NumericLimitTest")? Str(RunState.Step.Result.Numeric,"%$2.2f"):( (RunState.Step.StepType.Name == "NI_MultipleNumericLimitTest")?Str(RunState.Step.NumericArray,"Value: %$2.2f "):" ")
Try out changing was is displayed and see what all you can show your operator at run time or your deveoper at edit time.
Requirements
Software
NI TestStand
