Example Code
Increasing frequency Digital Array Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This piece of code was written to simulate an increasing frequency digital wave. Array
Description
Instead of using the counters to output varying frequencies, this VI can be directly used with a clocked Digital Output to produce a varying Frequency Square wave. It works by slowly reducing the number of waveforms that are put together in the
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the vi
  2. Waveform will generate on the graph
Additional Information or References
Labview front panel
Andrew McLennan
