Overview
This example works to set all DSA devices and their available channels to the first non-zero excitation level.
Description
This code will set all DSA devices and their available channels to the first non-zero excitation level. This can be set to run as a start-up program. The goal is to run this before acquisition while the sensors are connected to allow for sufficient settling time and to allow the sensor to reach steady state.The necessary EXE file is attached, along with the source code VIs.
Requirements
Software
Hardware
Additional Information or References
