Example Code
Insert Comments into File during Data Acquisition
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This program allows you to insert comments into the data file as you're collecting data.
Description
This application is especially useful when you enable "End text entry with Enter key" option under Tools»Options»Environment (otherwise you'd have to use the Enter key or click outside the text box for the text entry to register). Also, you probably want to use the "One header only" option of the Write to File Express VI.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Double-click on the DAQ Assistant to configure and select your data acquisition device
  2. Double-click the Write To Measurement File to select the file path
  3. Run the VI
Misha
Comments
Todd S.
NI Employee (retired)
on
Great stuff.  Thanks for posting!
Todd S.
LabVIEW Community Manager
