Example Code
Insert Data into DataBase from an Array using LabVIEW Database Connectivity Toolkit
Products and Environment
    Software
  • LabVIEW Database Connectivity Toolkit
  • LabVIEW
Code and Documents
Overview
This example inserts data into a database from an array in LabVIEW using the Database Connectivity Toolkit.
Description
When writing data to a database, you may have the data in array format, with each array element corresponding to a different column of the database. This example allows to easily write array data to your database: each array element will be written to a different column in a desired database table.
  1. Select the UDL file for the connection information to the desired database. You can run this example using LabVIEW.udl connection file for the LabVIEW.mdb database provided with Database Connectivity Toolkit examples. To create a new database instead,  you may also consider DATABASE CREATION PROCEDURE.pdf available here
  2. Set the desired Table Name and Columns
  3. Write the data to insert into the Database in Array Input Data control
  4. Run the VI
Requirements
  • LabVIEW 2012 (or compatible)
  • Database Connectivity Toolkit 2012 (or compatible)
Additional Information or References
VI Block Diagram
Insert Array Data into DataBase LV 2012 NI Verified.pngInsert Array Data into DataBase LV 2012 NI Verified.png
Salvador Mikel
Ingeniería de Aplicaciones
www.ni.com/soporte
Comments
parii
Member
Member
on
i do it but it shows error..no of coloumns does not equals to parameter .what does it means
ijustlovemath
Active Participant
Active Participant
on
Perhaps you should see if the number of columns you're inserting is equal to the number of parameters you're inserting.
