Overview: This VI inserts an item into a queue in any desired location rather than being restricted to only the begininning or the end.
Description: The example is set to using numerics as the queue elements but this can be changed to any data type.
Requirements: LabVIEW 2012 (or compatible). Hardware: none.
Steps to Implement or Execute Code:
1. Enter a value into New Queue Item.
2. Select the desired position of new item.
3. Run the VI.
4. Check Before and After arrays.
Additional Information or References:
