Example Code
Interactively Extract The Color Of A Pixel From A 2D Picture
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates how you can interactively extract the color of a pixel from a 2D picture.
Description
Have you ever wondered if you could find out the color of a specific pixel on an image? That's exactly what this example does. Run this VI and pick any JPEG image on your computer. An example image is already provided with the VI.
Mouse over the picture control and find out the exact color your mouse is over and the coordinates your mouse is hovering over within the picture identifier.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached ZIP-file
  2. Open the VI and follow the instructions on the Front Panel
Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Raj
Comments
Hooovahh
Proven Zealot Proven Zealot
Proven Zealot
on
There is a bug with this that it doesn't take into account and scrolling of the image.  So if you load an image and then scroll down it no longer selects the right color properly.  To fix this read the Origin property, and add it to the offset inside the Mouse Move event.
