Overview
The example is to demonstrate how to internally read the generated signal from the analog output
Description:
Leveraging the ability to route, we could access the signal generated from the analog output referenced to the ground with the analog input of the same DAQ Hardware, eliminating the need to externally wire the pins. It may be beneficial for the need to quick check of the hardware capabilities. For this example, the signal that would be generated is a sine waveform.
Steps to Implement or Execute Code:
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Analog Input and Output Module
Dan King
