Example Code
Jump to Last Array Element on a Touch Panel
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to jump programmatically to the first or last element of an array indicator.
Description
When using an array in a LabVIEW Touch Panel application, you cannot use the Show Last Element shortcut in the context menue. Although you can change the index value to scroll through the array, you cannot jump directly to the end.
This VI allows the user to jump to the first or last element of an array by clicking a button.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached VI
  2. Run the program
Additional Information or References
Jump Programmatically To The First or Last Array Element - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Jennifer R.
