Example Code
Karnaugh Map/Truth Table converter using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example allows the user to quickly convert between the karnaugh map and truth table visulaisation
Description
This example allows the user to quickly convert between the karnaugh map and truth table, two common ways of expressing a logical circuit.  The VI can handle 2, 3 or 4 input values.
Requirements
LabVIEW Full Development System 2012 or compatible
  1. Run the VI
  2. Select Number of Inputs (2,3,4)
  3. Change the values on the Karnaugh Map LED buttons or the Output in the truth table and notice how it changes on the other hand
 Additional Information or References
VI Front Panel
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Al B.
Staff Software Engineer - TestStand
CTA/CLD
