Overview
Event driven gui to control the Keithley 2304A Power Supply.
Description
2304A Power Supply.vi is the top level vi. Let me know if anyone has trouble opening or using the vi. ****Open up rst.vi and cls.vi first - the search engine tries to open power supply.lvclass which is not there. Press Ignore Item. When the vi opens with a broken arrow select File>Disconnect from Library.I will try to get an update version soon, one that does not have the issue.
Requirements
Software
LabVIEW 2012(or compatible)
NI-VISA
Dear, trying to use your vi for the 2304A power supply. Got the 2 errors you have mentioned above with broken arrow. gui.PNGNow another error comes up as global functional Vi broken.
please guide on how to open the main Vi.
