Overview
This example was written to show how event structures and property nodes can work together to move a cursor on a graph by using keystrokes.
Description
In the attached example, certain letters on the keyboard (A, D, W, and X) are programmed to move the cursor in certain directions by using event structures. Other properties are also made available for the user to modify during run-time. Instructions are also included for how to exclusively use the keyboard to execute the VI.
Requirements
Additional Information or References
Reference
How Do I Programmatically Create a Cursor for a Graph in LabVIEW?
VI Block Diagram
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
THANK YOU.....
I WANT TO CONTROL CURSOR WITH USING KEYBOARD ON MY GUI.
SO CAN I DO THAT? & IF I CAN THEN PLEASE HELP ME WITH THIS
