Note: NI is no longer updating Data Dashboard and the Data Dashboard download is no longer available on the App Store nor Google Play. Consider using WebVIs for your LabVIEW-based web application needs.
Description:
This program displays scrolling text via LEDs on an iPad using Data Dashboard.
Installation Instructions:
On PC:
1. Open the attached LabVIEW Project.
2. Open the LED Boolean.vi.
3. Run the VI.
On the iPad:
3.1 Click on each Shared Variable button as shown below and click the Shared Variable Editor (Green Icon).
3.2 Choose the property that you would like to modify.
3.3 Select your connection (this will be Shared Variables if you are hosting them from a host computer).
3.4 Enter your Server IP or host name.
3.5 Select the LEDBoolean Web Service Library.
3.6 Select the variable assocated with the control.
4. Repeat Step 3 for each Shared Variable and Web Service.
5. Run the Application.
6. Change the LED Text pull down to display other words.
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
