Example Code
LabVIEW Add Cursor Comment to Graph
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to add simple cursor comments to a graph and how they should look.
Description
Some applications might require messages on cursors. This example shows how we can accomplish this with property nodes to determine the position of the lowest and highest values on a graph. We use the cursor comments to accomplish labeling them.
Requirements
LabVIEW 2012 (or compatible)
1. Run the VI.
Additional Information or References
Sincerely,
Jason Daming
http://www.ni.com/support
