Overview
Coding that exemplifies the efficiency improvement by having parallelism in the data.
Description
Since LabVIEW is built to handle multithreaded applications, you can use a technique called data parallelism to split up operations to run on multiple processors at the same time. This example compares the execution time necessary to multiply two 500 by 500 matrices in one single operation versus dividing the matrices into two subsets each, performing the multiplication and combining them to a 500 by 500 result. The speed up time is displayed and the VI stops.
Requirements
LabVIEW 2012 (or compatible)
1. Run the VI.
2. The Speedup indicator will show how much faster the two data set management is in compared to one data set.
Additional Information or References
