This widget could not be displayed.
Example Code
LabVIEW Deep Learning with Python Keras API.
Products and Environment
    Software
  • LabVIEW
    Operating System
  • Windows
    Programming Language
  • Python
Code and Documents
Description
Overview
This example shows how to use the deep learning API to perform numeric classification using the Python Keras library. The model is of sequential type and is compiled using the optimizer provided by Keras. Trained using the mnist dataset, this model recognizes and classifies numbers you draw on the front panel.
Description
This example compiles and trains the model defined in main.py. The model uses a mnist dataset of 28x28 size images provided by Keras and outputs the result by predicting the number drawn on the front panel.
Hardware and Software Requirements
  • LabVIEW 2018 64-bit and later
  • Python 3.6 64-bit
  • TensorFlow Python library.
  • Keras Python library.
  1. Make sure you have TensorFlow and Keras installed in your Python environment.
  2. Open mnist Keras.vi.
  3. Run the VI. After the model has been compiled and trained, the Status indicator changes to "Model_Predicting".
  4. Drag the mouse into the draw pane to draw a number and the model will output the prediction.
Additional Information or References
Front Panel:
Jinho Choi
Staff Technical Support Engineer
Comments
Aht22
Member
Member
I run this code but LabVIEW crash when i run it please help me in this regards
Contributors
