Example Code
LabVIEW Embedded Module Serial Repeater Example
Code and Documents
Description:  This example uses an MCB 2300 ARM target and the LabVIEW Embedded Module for ARM Microcontrollers to read and write from the serial port. Serial data is written from the host to the target and then written from the target back to the host.  This example requires LabVIEW 2010 or later and the LabVIEW Embedded Module for ARM Microcontrollers. To run this example just open the project and run ARM Serial Repeater Main.vi. This will compile and download the code to the ARM development board. Then run the PC Terminal Main VI to send serial data to the ARM target.
Host VI Front Panel:
Host VI Block Diagram:
Target VI Block Diagram:
Kevin Fort
Principal Software Engineer
NI
Contributors
