Description
Description-Separate-1This application allows you to easily configure a Form Data control so you can prompt a user for data then easiesly write it into a spreadsheet file (.csv). This form automaticly supports string, integer, enum, and boolean data entries. You can easily ad your own data types if you need something else custom.
This code uses functions from the OpenG Libraries. Get all of their functions for your self.
Description-Separate-2
