Input is given to AI port by function generator of frequency 10 Hz and amplitude 4Vpp. The input range is -2 V to +2 V. For the analog input mode, the user has the option to select the DAQmx Global Channel.
There are two configurations in analog input in NI DAQ-
NI USB-6002, LabVIEW
1. Connect USB-6002 through USB port.
2. Input is given to AI port by function generator of frequency 10 Hz and amplitude 4Vpp. The input range is -2 V to +2 V.
3. Download NI-DAQmx 18.0.0, Execute sample code "USB6002-AI0S" and run it.
4. Monitor the waveform.
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288275
