Analog Output mode allows user to use the DAQ device as a normal function generator with the options to select the frequency and amplitude. The user needs to select the DAQmx Global Channel for output. Then output is generated on oscilloscope through hardware ports.
Analog Output mode, follows the same configuration as Analog Input. USB-6002 has two ports and one common ground. It also has trigger option from PFI0 and PFI1 ports.
NI USB-6002, LabVIEW
1. Connect USB-6002 through USB port.
2. Download NI-DAQmx 18.0.0, Execute sample code "USB6002-AO(100 Hz)" and run it.
3. Connect the oscilloscope through AO port. Enter the frequency and amplitude.
4. Monitor the waveform on oscilloscope.
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288275
https://www.ni.com/en-us/shop/model/usb-6002.html
