Example Code
LabVIEW Miracle!
Code and Documents
Overview
This program guesses a number that you pick between 1 and 63.
Description
This progam implements a number game within LabVIEW.  It prompts you to pick a number between 1 and 63. It then asks you a series of questions to determine which number you selected.  This program displays good use of SubVIs to reduce block diagram clutter.
Steps to Execute Code
1. Open LabVIEW Amazing.llb
2. Open The Amazing LabVIEW.vi
3. Click the Run button
4. Read the instructions, pick a number, and press OK
5. Answer the questions on the following 6 cards
6. Be amazed!
Requirements to Run
Software
LabVIEW 2012 or later
Hardware
None
Additional Images
Contributors
