Overview
This is a LabVIEW application which can determine the value of a resistor using a cheat sheet.
Description
Ever used a cheat sheet to determine the value of a resistor?
Here is a LabVIEW application which does the 'hard work' for you! The following example can be used for 4 and 5-code resistors.
Requirements
Additional Information or References
Front Panel
VI Snippet
There are a couple of examples on the community pages which provide this functionality, however this implementation uses Picture Rings as the control method and is built to allow distribution as an executable.
