Example Code
LabVIEW: Writing a String Array to a TDM Channel Group Property
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to write a string array to a TDM Channel or Channel Group Property.
Description
The following VI will write a string array to TDM Channel Group Properties. The channel property is set the value of the string array which is converted into a tab-delimited string by the Array to Spreadsheet String. The property is read using the Get Property subVI and converted back into a string using Spreadsheet String to Array. This VI is referenced in the Writing a String Array to a TDM Channel or Channel Group Property in LabVIEW KnowledgeBase.
Requirements
LabVIEW 2012 (or compatible)
1. Verify that the path of for the TDM file is valid on the Open Data Storage Express VI.
2. Run the VI.
Additional Information or References
Sara Lewandroski
Applications Engineer | National Instruments
