Overview
Example code written in LabVIEW which implements limit line testing. Measured X and Y values are compared to a number of user defined limit lines.
Description
Useful for checking if a frequency response (Spectrum Analyzer trace) or waveform (DAQ or Oscilloscope trace) are within certain limits. Any number of limit lines can be defined, limit lines can be diagonal.
Includes a VI for adding points to the original data using interpolation / curve fitting.
Requirements
LabVIEW 2012 (or later)
1) download the zip and extract the play limit line.vi
2) run the vi with relative library file
Additional Images or Video
