Example Code
Linear Curve Fitting a Random Waveform Graph
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview: This VI uses a loop structure to create a linear graph with random "noise".
Description:
This VI uses a loop structure to create a linear graph with random "noise". This is done by adding the random number generator VI to a linearly increasing y value. Once the graph is created, a linear fit VI will fit the best curve to it display it on the front panel.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute Code:
1. Run the VI.
2. The results are on the graphs.
Additional Information or References:
Chris Van Horn
Comments
AllanNish
Member
Member
on
First, I'm a novice in LabVIEW programming. I opened this vi, but it's unclear to me how I input the waveform data. I think this is the vi that will fit perfectly into my program. Could anyone help?
