Example Code
Listbox Tips and Tricks
Products and Environment
    Software
  • LabVIEW
    Programming Language
  • LabVIEW G
Code and Documents
Description
This example contains tips and tricks for using LabVIEW listboxes.  It is hoped that the community may find it useful and add additional tips and tricks to it as explained in The Example Programs Process.  The example includes the following:
  1. Making it easier to edit the contents of a listbox
  2. Using Checkbox symbols to allow users to check listbox items
  3. Dragging items in a listbox
  4. Instructions about strict and non-strict listbox references
The attached zip file contains LabVIEW files saved in LabVIEW 2015.
How to Use
This example was created to capture tips and tricks about listboxes, but it is in no way complete.  Download it and see if you can learn anything from it, and possibly add examples to it.
