Overview
This is a virtual lock-in amplifier using DAQmx devices.
I provide this as "AS-IS" code. There may be a bug. forgive me.
Description
Here is the concept diagram for lock-in amplifier.
Hardware and Software Requirements
[Hardware]
- Analog Input DAQmx Devices
- Analog Output DAQmx Devices (If you don't have signal source)
[Software]
- LabVIEW Full Development System 2014 or later
- DAQmx driver
Steps to Execute Code
Run LockIn.vi
PLL_Sub.vi is a sub vi inside LockIn.vi
If you don't have signal source, please use AO Sample.vi
Additional Information or References
