Example Code
Low Frequency Standard Waveform Mode Generation on the PXI-5422
Products and Environment
    Hardware
  • Modular Instrumentation
    Software
  • LabVIEW
    Driver
  • Other
Code and Documents
Overview
This illustrates how to modify the buffer size to produce the approporiate waveform at low frequencies(< 38.147 Hz) with a PXI-5422 device.
Description
This example examines whether the output frequency is lower than the minimum frequency. If so, an expanded buffer is aassigned to the Fgen task.
Requirement
Software:
    Labview 2012 (or compatible)
    NI-Fgen driver which is compatible with your hardware and version of LabVIEW
Hardware:
    PXI-5422 device
1. Check the frequency of the desired waveform
2. If < 38.147 increase the buffer size to 5000000
3. Run the VI
Additional Information or References
Block Diagram
Dustin D
