Overview:
Demonstrates on generating output frequency sweep from a DAQ device and acquire the generated signal from another DAQ device.
This frequency sweep allows user to use the data to form a Bode plot.
Description:
This VI implemented the Producer-Consumer Design Pattern whereby the Producer Loop programs the DAQ devices to generate and acquire the data followed by sending the acquired data to the Consumer Loop to be logged into a TDMS file.
Steps to Implement::
1. Configure the the controls on the front panel for the right channel and devices.
2. Connect the hardware appropriately.
3. Run the VI.
Requirement:
LabVIEW 2012 or compatible.
NI-DAQmx 15.5.1 or compatible.
