这是一个“4轨”鼓机,它按照可自定义的节奏模式发送MIDI音符命令。在我的 Windows 计算机上,声卡为设备 =0,鼓声库为通道=10。我已经成功地使用此代码来控制外部MIDI乐器和VST乐器。这些模式可以手动操作或随机化,以获得无限的可能性。我把这个放在那里不是为了对我的编码进行批评 - 它就是这样。这不是一个金星的编程例子,我绝对认为自己是业余爱好者/新手,但想分享一些我认为有趣且可能有用的东西。
Description-Separate-2The program starts out with 4 default drum patterns. One for each track. Each track triggers a different percussion instrument. The instrument can be selected via RING selector, starting with the "sound group" and then the precise sound/instrument.
How-Separate-216 steps make up 4 beats with 4 steps per beat. The notes are sent via MIDI to the internal PC soundcard on channel 10. Each note represents a different percussion instrument. Timing and synchronizing was somewhat tricky and if there is too much going on with Windows, there could be lags and sluggish timing.
Additional-Separate-2
https://www.midi.org/specifications-old/item/gm-level-1-sound-set
Related-Separate-2
Forgot to mention - developed with LabVIEW 14.0 Base Development System (32-bit)
*32-bit* may be a critical caveat
