Example Code
Make Front Panel Fullscreen While VI is Running in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example expands the Front Panel size to fit full screen except the task bar
Description
This VI will take the desktop space available and fill it with the front panel. Once the stop button is pressed, the VI takes the initial values for the front panel, before it is ran, and returns it to the original size.
Requirements
LabVIEW Base Development System 2012 or compatible
Run the VI, the Front Panel will fill the full screen area
Press the Stop button to restore the window size to its initial size and location before running the VI
Additional Information or References
VI Block Diagram
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Chris Van Horn
Comments
D.Romito
Member
Member
on
Without you I'd never find that App Property Node.
Special Thanks.
juventino001
Member
Member
on
thanks
juventino001
Member
Member
on
good evening
anyone knows how to video (WMP), activating you the fullscreen option
excuse the translator
Thank you for the cooperation
