You can perform basic manipulation of multi-dimensional arrays using the TestStand expression language, but more complex tasks are better suited for a code module. This example shows how you can perform basic manipulation on a multi-dimensional array.
Note: For manipulation of single dimensional arrays, refer to Example: Manipulating Arrays in TestStand Expressions
You can perform the following operations on multi-dimensional arrays within the expression language:
The following more advanced changes should be performed in a code module with more robust array manipulation capabilities, such as a LabVIEW VI or .NET assembly:
These tasks are not included in this example.
Initializing an Array
Initializing a multi-dimensional array using an array literal is not possible directly since the array literal format only supports single dimensional arrays. However, TestStand does provide a way to reshape a single dimensional array into a multi-dimensional array, which you can use to initialize a 2D array:
Locals.Array2D = {1,2,10,20,100,200},
Locals.Array2D.Type.ArrayDimensions.SetBounds({0,0},{1,2})
You can use a similar technique to initialize a large array to a single value, using the single dimensional array functions to generate the elements, then reshaping it into a multi-dimensional array:Locals.Array2D={},
SetNumElements(Locals.Array2D, 100),
SetElements(Locals.Array2D, 24),
Locals.Array2D.Type.ArrayDimensions.SetBounds({0,0},{10,10})
Obtaining an array subset
You can access a single row or column of an array using the ".." notation, as shown:
Locals.SingleColumn = Locals.Array2D[0..][1], Locals.SingleRow = Locals.Array2D[0][0..]
Using "[0..]" will obtain the entire row. Alternatively, you can specify a range of elements, such as "[2..3]" to obtain a subset of a row or column
Setting an Array Element
You can set individual elements using the following syntax, similar to single dimensional arrays:
Locals.Array2D[1][2] = 222
Clearing All Elements
Similar to a single dimensional array, you can clear a multi-dimensional array using an empty array literal.
Locals.Array2D = {}
TestStand 2014 or Compatible
Thanks Kurt for posting. Could you please resave the seq file at 2013 test stand version? I have 2013 and can't open the 2014 file.
