This example demonstrates the recommended approach for manipulating array data in TestStand
Note: For manipulation of multi-dimensional arrays, refer to Example: Manipulating Multi-Dimensional Arrays in TestStand Expressions
When working with arrays, there are common operations that you may want to complete within your test sequence without the need for a code module, including:
The expression language provides functions which allow you to accomplish these tasks with one-dimensional arrays:
Initializing an array to a set of arbitrary values
If you have a set of values in mind for the array, you can initialize the array using a literal, for example, an array with the values {1,2,3,4}:
Locals.Array1D = {1,2,3,4}
This statement will overwrite any data in the property and overwrite it with the specified array.
Initializing an array to a single value for all elements
If you need to create an array with many elements of a single value, such as 100 elements with the value -1, the previous method would be cumbersome due to the long array literal string. You can use the following functions to set the array size and set the value of all elements
SetNumElements(Locals.Array1D, 100), SetElements(Locals.Array1D, -1)
The SetElements function also supports specifying an array index or range of indices to set a range of values within an array:
SetElements(Locals.Array1D, 42, "[3..5]")
Adding elements at a specified index
You can add elements at a specified index using the InsertElements function:
InsertElements(Locals.Array1D, "[3]", 5)
Removing Elements starting at a specified index
You can delete elements of an array using the RemoveElements function. Be sure that the number of elements you set does not exceed the size of the array
RemoveElements(Locals.Array1D, "[1]", 2)
Clearing all elements
You can clear an array by setting it to an empty array literal:
Locals.Array1D = {}
TestStand 2014 or Compatible.
