Example Code
Manipulating your application's registry values and keys
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This LLB demonstrates a simplified and standardised method of manipulating your application's registry values and keys
Description
Using the registry for storing your application's setup values and other information is very convenient. However when you explore these possibilities you constantly run into warnings about danger of ruining your computer. The purpose of this project was to make registry access safer and easier. All editing is forced to occur in root key HKEY_CURRENT_USER, sub key SOFTWARE\MyKey preventing accidental alterations of other registry settings. Additional sub keys can be created in sub key MyKey.
Running the example:
  • Open LLB
  • Open vi Read and Write to registry example.vi
Run vi
Requirements
LabVIEW 2012(or compatible)
Additional Information or References
VI Block Diagram
