Example Code
Mass VI Documentation Editor
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This VI enables you to review and edit VI documentation quickly for all the VIs in a specific directory.
Description
This tool could easily be modified to an individual’s/companies needs to assist in everyday programming as well as peer code review. Example set requirements on free labels sequence structures and use the tool like VI Analyzer on the fly. On a side note I choose not to use an Enum for the states so the VI wouldn’t be dependent on a type.
It is a great example to demonstrate the power of VI Server/Scripting to assist in everyday programming task.
Requirements
1. LabVIEW 2012 (or compatible)
2. VI scripting
1. Run the VI
2. Select and load directory of Vis to review/edit
3. Begin to edit documentation quickly
Additional Information or References
Herrlin
Just trying to spread the LabVIEW love.
Comments
yokohama_turkey
Member
Member
on
hello!  [Traverse for GObjects.vi] can't find.
where is this vi ?
herrlin
Member
Member
on
Should have mentioned in my doc you need to have VI Scripting installed, it free see link.
https://www.ni.com/en/support/downloads/tools-network/download.labview-vi-scripting.html
Herrlin
WiMAX_Eng
Member
Member
on
Could this be made available in LV 8.6?
GRamy
Member
Member
on
i really like this application....goodjob
