Overview
These Vis allow you to see frequency and amplitude as a function of time.
Description
These Vis are a modification of the Sound and Vibration example Sound Level Meter found in the NI Example Finder under Toolkits and Modules » Sound and Vibration » Analyzing and Processing Signals » Sound Level Measurements. The Vis are modified to show frequency as a function of time by using the Extract Single Tone Information.vi.
Requirements to Run
Software
Hardware
DAQmx version:
Simulated Version:
Sound and Vibration Software Overview and Comparison
Two Vis are attached. The simulated version includes a simulated signal. For the DAQmx version, it is ready to use with your device.
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
