Overview
This VI calculates the first second and third quartiles (Q1, Q2, Q3) based on the third method dicussed here: http://en.wikipedia.org/wiki/Quartile
The second quartile can also be called the median.
There are multiple ways to calculate quartiles, this only implements one of them..
Description
LabVIEW does already have a VI for calculating the median (called "Median.vi"), but it was convenient to include a G implementation of it here.
Requirements
Just Input the data and run the VI, you can see the Q1, median and Q3 output.
Additional Information or References
Block Diagram
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
