Example Code
Minimum distance (ring thickness) finder for a ring within an image
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
This code demonstrates how to use the NI Vision Development Module (VDM) VIs to locate the minimum ring thickness.
Description
It is necessary in some applications to determine the minimum distance (thickness) of a ring. This is especially important for goods like gaskets or pipes.
To do so, you can use a camera with the NI Vision Development Module (VDM).
The VDM provides a VI which is able to locate the inner and outer rim of a ring. This information can be used to calculate the minimum thickness of the given ring. This example demonstrates how to use the functions of the VDM and gives you an easy way to play with the different settings available.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI Vision Development Module 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached Zip-file
  2. Open the VI and follow the instructions inside
Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
--Michelle
