Overview
This example demonstrates how to programmatically edit groups and channels on an existing TDMS file within LabVIEW.
Description
The project contains two VIs (and example data files). The main VI creates a new TDMS file with three groups, each with its own channel and data. The subVI is then called to convert the TDMS file to a TDM file in order to remove the specificied group. Finally, the main VI opens a TDMS File Viewer to observe the TDMS changes.
Requirements
Additional Information or References
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
