Example Code
Monitor values up to 1 and then keep a constant signal
Code and Documents
Overview
This example VI is the base for a user that wants take voltage inputs up to a certain voltage value. This specific program uses a case structure to plot randomly generated values up to one and then only plot a value of one if the randomly created value is greater than 1.
Description
The code provdided adds two randomly generated numbers and then compares them to one. If the generated value is greater than one, then a constant of one will be outputed.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI "Filter 2012 NIVerified.vi"
  2. Run the program
Additional Information or References
VI Block Diagram
