Functional Description
This example allows the user to get an image output that is the weighted sum of two chosen images. A slider control that goes from 0 to 1 determines the weightage of both images in the sum. For example, in the case of Images A and B, a slide value of 0 would result in a sum of 0% A + 100% B. When the slide value is 1, sum = 100% A + 0% B.
Caveats and Additional Notes
LabVIEW 8.2, Vision Development Module 8.6
Thanks for posting, could you please add screenshots of your block diagram and front panel!
Hunter
