Example Code
Multiple Data Type Queue using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to send different data types using a single queue by using a variant data type.
Description
This application allows the user to send multiple different data types using a single queue. It works through converting the data to a variant data type in the producer loop and combining this with an enum to specify the data type being stored in the queue. In the consumer loop the enum specifies the case in the case structure where a Variant to Data function is used to convert the data back to its relevant data type. The following screenshot is the front panel of this application showing that you can enqueue a number, string or boolean into the queue.
Requirements
  • LabVIEW Base Development System 2012 (or compatible)
  1. Unzip the attached folder “Multiple Data Type Queue 2012 NIVerified.zip”
  2. Open the VI "Multiple Data Type Queue 2012 NIVerified.vi"
  3. Run the VI
Additional Information or References
VI Block Diagram
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
