Description
This application demonstrates how to use DAQmx to create multiple PWM channels and have runtime-control over Frequency and/or Duty Cycle.
Steps to implement or execute code
To implement this example:
- Set the physical channel of the counter
- Determine the frequency
- Run the VI
- (Optional) Turn on the Highlight Execution to see the flow of the VI
To execute this example:
- Install the required software.
- Connect the DAQ hardware that supports the Counter features
- Confirm the connection with the MAX with TestPanel
- Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series Counter Input Module
