Overview
This example was created to provide the 5660 with the same functionality as the RFSA Frequency Sweep VI.
Description
This code consist on generating a frequency sweep with the 5660. It uses specific functions for this device that comes with the RFSA driver.
Requirements
LabVIEW 2011 (or compatible)
NI RFSA 2.6 or compatible (Verify that it provides the ni5660 VIs)
1. Configure the 5660 parameters.
2. Run the VI
Additional Information or References
This program was built in LabVIEW 2011 so you will have to have LabVIEW 2011 and the NI-RFSA driver installed on your computer to run this example.
